Det verkade som om folk inte var helt överrens om vad som gällde angående detta.
Här säger man t.ex att längden på varje enskild exponering inte spelar så stor roll, dock att man får mer utläsningsbrus med kortade exponeringar då man antagligen har fler av dessa. Det låter ju rimligt tycker jag.
Men sedan påstås detta, att om man kör med kortade exponeringar så kommer kanske inte alla innehålla den signal man är ute efter och vid stackning så kommer denna oregelbundna signal tolkas som brus. Det låter ju också rimligt, men stämmer det verkligen?Counting photons is mathematically the same thing as counting drops of water
from a leaky faucet. If you fill a bucket and then weigh it, you will get one
answer. If you fill many teacups and then dump them into the bucket, you will
get the same answer. Viewed in this oversimplified way, it doesn't really
matter whether you take long exposures or short exposures.
BUT (there always is a "BUT"), this ignores the fact that each time you read a
CCD camera, a certain amount of noise is added. It's as if a little extra water
spattered out of the faucet every time you moved a teacup near it. In that
case, using a bigger bucket would mean fewer opportunities to capture spatters,
and therefore a more accurate answer.
Här är man inne på samma linje.Again, this is my understanding so please correct me if I'm wrong. I think the point is that say a photon from one particular region of of faint nebula only hits the sensor once every six minutes. If you do eight minute subs, you are likely to capture photons from that part of the nebula in each sub. Deepskystacker will stack the subs and will build up the SNR for this region of the nebula. However, if you take only two minute subs, your chances of capturing photons from that region in every sub is small. As I stated below, given signal from these photons won't be captured in each sub, deepskystacker will think it's noise in the combined photo.
Men sedan kommer detta svar att även om du inte fångar signal i alla exponeringar så kommer den att framträda tillslut ändå.For example, to image a very dim galaxy around 11th or 12th magnitude, 1
minute sub exposure may not be enough even if you stack 1000 x 1 minute
sub. How can a non-existent signal of each sub ever show up after
stacking? The solution is to raise the sub-exposure. What's the maximum
sub-exposure? That depends on amount of light pollution in your area.
The worse the light pollution the shorter the sub-exposure.
Då påstår man att liknelsen inte stämmer efter som datat inte summeras utan beräknas via medelvärde (stämmer den tolkningen?)The answer to your comment is "statistics". It's true that when your exposure
times are short, most of your subs won't receive any photons. But every now and
then a sub will get an extra dose of photons. On the average, these subs will
all add up to the right number of photons. It's just like my teacup analogy.
If the faucet drips slowly, some teacups will be empty. But the faucet does
keep dripping, and as long as you keep the teacups at the ready, they will catch
all the drops.
Men här säger man dock att metoderna gör samma sak i princip, och att det i slutändan är nivån på utläsningsbruset som avgör hur långa/många exponeringar man kan ta.The fallacy in the teacup example is that the data is averaged not summed.
Jag blir lite förvirrad för jag tycker båda argumenten verkar rimliga.An average and a sum are mathematically the same thing except for the minor
inconvenience of dividing one by a constant to get the other. The only time this
doesn't work is if the faucet is leaking so fast that the bucket overflows.
Then you have to use the teacup approach. But as long as you are photographing
a dim astronomical target with a decent camera, this isn't an issue. Then it
comes down to how much readout noise you are willing to tolerate.
Hur blir det egentligen när man stackar exponeringar, om man har signal i säg varannan exponering, kommer man få samma resultat om man tar 20 sådana bilder som om man skulle tagit 10 bilder där signalen är med i varje exponering, eller kommer signalen tolkas som brus och tas bort?
Sen undrar jag lite om brus och SNR (Signal to Noise Ratio)
Följande påstående fick mig att undra lite.
Det betyder alltså att ju fler exponeringar man stackar desto minde effekt får varje enskild bild för slutresultatet, och att man måste ta hiskeligt många bilder tillslut för att minska ned bruset ytterligare. Stämmer den tolkningen?The random noise is reduced in proportion to the inverse of the square root of the number of frames. So, four frames yields 1/2 the random noise; nine frames, 1/3; sixteen frames, 1/4; 25 frames, 1/5; and so forth. Usually the reduction beyond about 25 is not worth the trouble
Stackning minskar ju bruset och ökar SNR, men vilken påverkan har exponeringstiden? Ökar man tiden så får man ju mer signal, men också mer brus från bakgrunden vilket borde betyda att SNR förblir densamma, eller? Kan man genom att ändra exponeringstid ändra SNR för enstaka exponeringar?
Lite luddigt är detta tycker jag, och hoppas att någon kan reda ut vad det är som stämmer.
Daniel
