Ny version av programmet vi älskar/hatar:
https://github.com/deepskystacker/DSS/r ... .0-Release
1. Support for images from cameras that use the Fujitsu X-Trans sensor (new in 4.2.0 Beta 2).
The image is converted to a 3 colour RGB image and interpolated using Frank Markesteijn's algorithm using LibRaw::Process().
Please note that the interpolation is quite slow (about 40 seconds per image on my Core i7 laptop).
The image is then imported as if it were a Foveon colour image.
2. BSD 3 clause license file added.
3. A fix was made to correct crashes caused by a thread-unsafe assignment in the smart pointer code.
4. The "Stop" button on the progress dialogs should now actually work!
5. The space key can now be used to check/uncheck images in the picture list.
6. The user's default browser will be used instead of IE to open URLs.
7. Miscellaneous code cleanups and performance improvements including Median-Kappa-Sigma processing.
Christer
DSS i ny version, nu 4.2.0
ZWO ASI 294 MC Pro
iOptron CEM40
ZWO ASI 294 MC Pro
iOptron CEM40
Re: DSS i ny version, nu 4.2.0
Tack för tipset Christer !
Tack Crister
Jag är en av de som verkligen gillar programmet och nu efter alla år ska äntligen stoppknappen funka oxå
Fan dom skulle ha en server och klient version.. dss är det sista jag har min stationära till nu
