[SÅLD] Sxv-h18 ccd mono till salu
Post by Bengt »
Ccd kamera i Full format
Min huvudkamera sista åren se bilder tagna med denna på
http://www.astropixlar.com" onclick="window.open(this.href);return false;.
Mitt ex av denna kameran är förbättrad av starlight express där de byta ut slutaren mot en som inte är målad.
Extra fläkt är monterad på denna se bild .
Lämnar med nätdel och 2” adapter som inte är original.
Data nedan om den
Specifications:
CCD type: Kodak KAF8300M full frame CCD with low dark current and lateral anti-blooming.
CCD Full resolution Pixel data: Pixel size: 5.4uM x 5.4uM, Image format: 3326 x 2504 pixels
CCD Image area: 17.96mm (Horizontal) x 13.52mm (Vertical).
CCD quality: Standard grade - No dead columns, no dead pixels.
Spectral Response: QE max at 540nM (~56%), 48% at 470nM and 656nM.
Readout Noise: Less than 8 electrons RMS - typically only 6.5 electrons.
Full-well capacity: Greater than 25,000 e- (unbinned)
Anti-blooming: Overload margin greater than 100x.
Dark current: Dark frame saturation time greater than 10 hours. Less than 0.05 electrons/second @ + 10C ambient.
Data format: 16 bits.
System gain: 0.35 electrons per ADU
Computer Interface: Built-in USB 2.0 compatible interface.
Image download time: Typically 4.5 seconds at full resolution using USB 2.0.
Power requirements: 115VAC / 240VAC @ 12VA, or 12VDC @ 750mA max.
Cooling system: Regulated constant current cooling supply with two stage thermoelectric cooler to give a CCD temperature of approximately -40C below ambient.
Size: 75 x 70mm black anodised aluminium barrel with 42mm 'T2' thread at the CCD window end & input/output plugs at rear. CCD alignment screws are provided for setting the chip parallel to the focal plane.
Back focal distance from front of camera to CCD: Approx. 23mm
Weight: approx. 400g.
4000 eller ge bud .
mejla bengt@astropixlar.com vid intresse
Re: Sxv-h18 ccd mono till salu
Post by Bengt »
Sänker till 4000kr
Starsoft
Post by Starsoft »
Skickat ett e-mail
Post by Bengt »
Såld
Return to “Säljes”
